pcv routes to a negative pressure line, creating a vacuum on the crank case, it does not pump air into the crank case. As far as moisture condensation, have you seen the pcv path from crankcase to intake? If you think you will not get condensation on every baffle and hole on its path to the intake, then your logic is flawed.
